300 Hand crank advice please
Posted by RICK/OASIS ID on March 06, 2006 at 13:00:44 from (207.200.116.5):
I have the 300 tore down for overhaul. I thought it would be nice to free up the hand crank while i have the wide front off. That part was a piece of cake. The main rod that the handle connects to is brocken off at the bolt hole. (i assume this is where the handle bolts on) Will it be easier to weld a piece of solid stock back on or should i replace the whole mechinism while i have it apart. I still have to find a handle for this one Thanks Rick
