Re: Farmall 350 Frontend loader
Posted by IaGary on March 06, 2006 at 15:11:09 from (207.199.245.90):
In Reply to: Re: Farmall 350 Frontend loader posted by RICK/OASIS ID on March 06, 2006 at 13:06:34:
The frame is narrower on a 300 than the M I believe, But that is good because all you have to do is shim the loader brackets about 1" where it bolts to the frame rails on the 300.
With the wide front make sure the loader has the curved arms to clear your axle.
I sold a freeman all hydraulic loader off a 300 for $600 in 2005 that needed the bucket replaced.
My 2 cents and good luck.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
