Re: Super A belly mower vs newer residential mower
Posted by ddg on April 09, 2009 at 13:18:04 from (66.45.132.217):
In Reply to: Super A belly mower vs newer residential mower posted by bluegrasmtns on April 09, 2009 at 06:04:20:
I"ve used a SA with Woods L-59 for 25 years to cut about 2-1/2 acres. I finally broke down & bought a 52" Hustler ZTR with a 19 HP Kawasaki 2 cyl. I cut my mowing time by 1/3 and eliminated string trimming completely. But the ZTR is very noisey and dirty, throws up clippings & dust all the time. The SA was smooth & quiet, & didn"t need ear plugs. Also I took the wheel weights off the SA, but it still compacted the yard too much, the ZTR has softer, wider tires. Both pretty easy on fuel. I fly light sport aircraft, so still use the SA to mow the runway.
