Re: whats the smallest tractor you run a PTO Gener
Posted by Nat 2 on March 07, 2006 at 11:38:38 from (64.80.108.53):
In Reply to: whats the smallest tractor you run a PTO Generator posted by Cory R. on March 07, 2006 at 09:45:36:
Depends on how big the generator is... If yours is making the old M snort, I'd guess it's probably in the 15KW range. Dad's got a 25KW, and he normally runs it with an 80HP Maxxum.
