Re: whats the smallest tractor you run a PTO Gener
Posted by FatRedneck on March 07, 2006 at 12:10:44 from (205.188.116.133):
In Reply to: whats the smallest tractor you run a PTO Generator posted by Cory R. on March 07, 2006 at 09:45:36:
if your worried about your M, go to a diesel engine tractor,it might sound crazy cause they're a pain to start but they're more fuel efficient and the torque of the diesel will keep it up to speed. i suggest at least a IH 400 diesel or larger, many newer tractors will work even better.
