Re: Froze Engine
Posted by MJ in the UK on March 08, 2006 at 09:55:56 from (195.92.168.163):
In Reply to: Froze Engine posted by Rick Paramino on March 08, 2006 at 07:55:31:
The way I have freed off a siezed engine several times is to remove the plugs, fill bores with tranny fluid etc. Put the cranking handle in the pulling up position then put a jack under the handle jack up till the front wheels are just clear of the ground. Then have patience and leave the tractor for a week thn go back and see if it has freed off at all. the only damage i have encounted doing this is a broken cranking pin MJ
