Whats It Worth???
Posted by Short Bolt on March 08, 2006 at 16:31:50 from (69.21.20.87):
Cleaning up in the shop found the optional hydrulic valve off Daddys 46 M. It has a bracket that bolts to the tank and a pipe that goes to the belly pump has a lever on the side that springs back when you push it down Has good red paint not busted chipped or stuck dose not have any hoses. Took it off when the loader came off. Any body have some good sound advice on what it should sell for? Thanks
