Re: m not getting any spark? not sure about wiring
Posted by Jarod on March 08, 2006 at 19:58:36 from (69.8.48.1):
In Reply to: m not getting any spark? not sure about wiring! posted by Booe on March 05, 2006 at 21:12:11:
One more very important thing with distributors. The battery must be grounded adequately. Positive or negative ground is irrelevant. If the cable is suspect or the engine is not grounded adequately because of paint, dirt, etc.... you will have strange and unusual problems with your ignition system as well as the rest of the wiring on the tractor. When everything checks out visually.....Check your ground first. Check for voltage at the right locations next.
