Re: 350TA
Posted by Evan350 on March 10, 2006 at 07:10:21 from (72.225.138.118):
In Reply to: 350TA posted by KIBB on March 10, 2006 at 06:26:14:
The PTO has both a clutch and a brake. With the handle forward (off) the clutch is off and the brake is on, with the handle back the reverse is true. If you're getting a whirr when the handle is forward, that means the clutch may not have completely disenguaged. On the top of the PTO housing, there's a cover over two screws that adjust the brake and clutch. How to make the adjustment is covered in the owners manual.
