Re: H rocker arms, two styles, straight and slante
Posted by Theman on March 10, 2006 at 10:33:27 from (65.248.77.5):
In Reply to: H rocker arms, two styles, straight and slanted? posted by arod on March 09, 2006 at 09:15:25:
I believe they will work interchangeably. The rockers in my "47 H are different from the ones in the "51 H. Check the valve contact point alignment and that the push-rods don"t rub the head castings anywhere.
