Re: Super A No Fire At Coil
Posted by Bob on March 10, 2006 at 14:08:25 from (64.21.249.40):
In Reply to: Super A No Fire At Coil posted by Sodbuster on March 10, 2006 at 13:39:06:
The ceramic thing is a "ignition ballast resistor", which drops the 12-Volt battery voltage to 6 to 8 Volts for the coil. If there is a wiring short between the resistor and the coil, a short in the coil itself, or a short between the coil and the points OR the points are shorted, or simply closed, the reistor will begin to heat up in short order with the ignition "ON". The heating, in itself, is normal. And, there must NOT be a blown fuse, or there would be no current, and no heating of the resistor. The first thing to do is rotate the engine to a point where the breaker points are open. Then, there should be no primary current, and the resistor should not heat up. If it heats up with the points open, we need to figure out where the short is! And, I suspect the "ancient-looking" coil may be an OEM IH coil that is of different construction than the typical "round-can" coils you are used to seeing. If so, the primary terminals will be at one end, with the high-tension "tower" at the other end.
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
