Re: 574 Brake Equalizer
Posted by Bernard le mécano on March 10, 2006 at 17:17:01 from (207.134.112.15):
In Reply to: 574 Brake Equalizer posted by TRC on March 10, 2006 at 05:28:28:
Hi TRC, may be the valve is worn and if you put a kit in it, it will leak by the spool. The TEE are available by an hydrolic shop. I've see many rebuilt valves leak, in the past, the solution, change the valve for a new or put two elbows. What's the problem with the brakes?
Bernard le mécano Québec Canada
