Re: Farmall 300 - Fifth Gear
Posted by GooseCreek Farms on March 11, 2006 at 03:24:38 from (152.163.100.65):
In Reply to: Re: Farmall 300 - Fifth Gear posted by Magman on March 10, 2006 at 18:29:26:
Response to your questions"
#1 - Yes, fifth gear is inside of fourth gear. #2 No, it doesn't slide on farther when you turn the wheel. I can't because it hits on the lower counter shaft "constant mesh gear". #3 I don't believe the shifter ball is worn. I did put the deck plate on and even the shifter. Then shifted it into fifth gear, but experienced the same problem. The gear did not properly engage.
