Re: Alternator again
Posted by farmallhal on March 11, 2006 at 11:16:50 from (64.24.35.17):
In Reply to: Re: Alternator again posted by Andrew Z on March 11, 2006 at 11:02:24:
I think that could very well be your problem. And yes, I used Bob's Super M diagram as well. I believe the function of the warning light or the resistor is to place a load on the alternator which starts it charging. I am certainly not a person with a lot of electrical theory background but I did do a lot of research before ever starting my conversion. I used the resistor because I couldn't easily locate the correct light as called for by Bob. If this fixes it get back to me as you still have one more little thing to do so it won't drain your battery. You need to get it charging first and get that portion behind you. Hope this helps, Hal.
