Re: Alternator again
Posted by Bus Driver on March 11, 2006 at 16:38:18 from (66.44.255.183):
In Reply to: Alternator again posted by Andrew Z on March 11, 2006 at 08:45:10:
The purpose of the terminal to which the light/diode/resistor is connected is primarily to supply a current to the alternator to get it to start charging- an exciter current. Once charging starts, additional exciting is not required as long as the engine runs at a reasonable speed. Exciting the alternator with the engine not running will discharge the battery. While charging, that exciter terminal on the alternator feeds current back through the wire connected to it. If that wire originates at the ignition switch, the back feed will continue to feed the distributor, if the tractor has one, and the engine will not stop normally when the switch is turned off. The light or resistor, if used, limits the back current to an amount less than that required by the ignition, thus the engine stops when the switch is turned off. The diode permits current flow in only one direction-to the alternator. My thought is that the light is the most fragile of these devices and the resistor is the most durable. IH used the resistor when they first put alternators on their tractors in the 1970's. It was a 25 ohm wirewound. I use a 5 watt wirewound 44 ohm unit on my conversions. The typical lamp used is about 54 ohms, so the ohm value is not critical. I selected the 44 ohm resistor as a popular size between 25 and 54. Works fine.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
