Re: 47 H Temp Probe Nut Broke off in Head
Posted by Tom Windsor on March 11, 2006 at 20:33:08 from (64.12.116.65):
In Reply to: 47 H Temp Probe Nut Broke off in Head posted by AH64D on March 11, 2006 at 18:47:02:
I believe in heat. It works...most of the time...sometimes it does not. I did the same thing with with an H twice. Once the heat got it and the other time it did not. I would do the suggestons that have already come forward but trying heat first...then sawing the sleeve second...then collaps it...as i recall, it will be difficult to get a dremmel in there...I took a hacksaw blade and ground it down to make it narrower and used that.
