Re: Farmall B won't move??
Posted by badgde bob on March 12, 2006 at 07:34:14 from (70.97.171.49):
In Reply to: Farmall B won't move?? posted by texasoldiron on March 11, 2006 at 20:02:29:
I have a 46 a that did the same thing it turned out to be the bolt and washer on the end of the pto shaft. it fell of and was jamed betwin thw case and the revers idler and it locked up the thing good. I just removed the top of the trany and jamed a screw driver in to remove it. this all hapened on a very cold day. I think that the geras was so cold that it sucked up the parts and thay became stuck in the gears. hope this helps and good luck. Bob
