Re: To the electrical experts
Posted by gene bender on March 13, 2006 at 04:43:49 from (66.43.221.211):
In Reply to: To the electrical experts posted by Cedric on March 13, 2006 at 01:37:21:
Your mag starts on tdc before going to the 35 deg when the engine runs. The dist can be set to have inital advance then go as a curve till it reaches the 33deg. Now if you have the machine that will check out the dist. you could set the curve higher and even increase the advance by changing springs and the wts.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
