Re: H hydraulic liftall
Posted by Janicholson on March 13, 2006 at 06:39:22 from (199.17.6.175):
In Reply to: H hydraulic liftall posted by farmallwayne on March 12, 2006 at 18:40:58:
The answers below are good, I would ad that some two way cylinders are used as a resivoir for fluid. If the tops of the lift cylinders are connected, I would suspect the cylinder/s. Pull it up to a barrel and set the loader on the barrel. Disconnect the hoses (leave them "Y"ed together from side to side) and cap/plug them at the loader, and tractor. back off of the barrel with the tractor (with everything clear) and see if the loader goes down as before. If it does it is one (or both) of the cylinders bypassing.
JimN
