Re: popping
Posted by old on March 13, 2006 at 10:07:59 from (207.69.137.43):
In Reply to: popping posted by randy on March 13, 2006 at 10:01:58:
Sounds like you still have carb problems and its running lean on you. If it has a main jet adjustment you need to open it up some if it doesn't you need to open the carb back up and clean it some more becuase you still have some junk in it
