Cub Positive Ground w/witch
Posted by courtland on March 13, 2006 at 12:26:45 from (146.243.4.157):
CUB with positive ground and it is wired "correctly", IF I turn-on the ignition switch, should the AMP meter read positive 6 Volts therefore discharging the battery??
