Re: Field Resistor
Posted by Bob M on March 13, 2006 at 15:30:33 from (69.205.121.140):
In Reply to: Field Resistor posted by Yugrotcart on March 13, 2006 at 14:50:05:
Going from memory here but I think the OEM field resistor is on the order of 3.0 or 3.2 ohms. The resistor should be rated at 10 watts or more - a resistor rated for fewer watts can overheat, burn out or even start a fire in the ammeter box.
As a practical matter however, unless you are an absolute stickler for originality I strongly recommend you ditch the cutout and field resistor and replace 'em with a voltage regulator.
A regulator does a much better job of maintaining the proper charging current to the battery, and it eliminates the risk of overcharging. For $35 or so it's money well spent!
