Re: 560 help again *It's back
Posted by the tractor vet on March 13, 2006 at 15:43:12 from (64.179.117.32):
In Reply to: Re: 560 help again *It's back posted by Steven@AZ on March 13, 2006 at 14:20:36:
Well if they are installed correctly and used properly they work just fine and now adays with the higher HP the old woven discs will not take the stress and the friendly EPA does not allow it . Now if the flywheel was not GROUND and the step was not cut correctly and your old foot is jumpy and ya did not seat the new clutch in then yes they do grab ahold , now they were not designed to be slipped so if you are a clutch slipper then guess what they will ware the flywheel and plate.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
