Re: 450 block
Posted by FatRedneck on March 13, 2006 at 17:09:46 from (152.163.100.65):
In Reply to: 450 block posted by Devin M on March 13, 2006 at 16:56:59:
a 450 block without sleeves should be as large as you ever need to go, butif your pushing your luck with boring the cylinders, get it bored as far as you can safely, idont know the exact specs, and get chevy pistons to fit. Janicholson, Chads, or the tractor vet can help you more than i can, just thought i'd put my two cents in.
