Re: Field Resistor
Posted by John *.?-!.* cub owner on March 13, 2006 at 20:19:55 from (66.112.35.68):
In Reply to: Field Resistor posted by Yugrotcart on March 13, 2006 at 14:50:05:
If you have a cutout with a term. marked FLD, it has a resistor to ground of the same value as used on the light switch. simply place add lead from it to the F term of the generator, and connect it on top of the one going to the light switch. The resiter in the cutout will provide the low charge, and when you put the light swithc on the high charge position or turn the lights on it will ground the lead and give you the high charge.
