Re: popping
Posted by rumplestiltskin on March 14, 2006 at 06:41:45 from (65.216.75.240):
In Reply to: popping posted by randy on March 13, 2006 at 10:01:58:
Randy -- Just a wild guess:
You may have a partially sticking exhaust valve rather than a burned one. It would close fast enough for a good compression check and good low-speed engine operation, but not fast enough to seal properly at high speeds.
This is similar to Greg_Ky's suggestion.
Mark W.
