Re: the alternator, still not right?
Posted by John T on March 14, 2006 at 13:19:59 from (66.244.90.98):
In Reply to: Re: the alternator, still not right? posted by Andrew Z on March 14, 2006 at 10:35:39:
Andrew, if its a "one wire" alternator all bets are off and DISREGARD all I said above. On a true "one wire" alternator its big main output stud wires to the load (NOT to battery/starter) side of the ammeter with 10 gauge wire. There would be NO 10 ohm resistor in the output of a one wire alternator (if thats what the Hitachi is???). Its most likey a Negative ground alternator, so be sure you changed the battery to Negative ground. If so the ammeter leads need to be reversed or else it will read bass ackwards plus the coil leads need reversed so - goes to the distributor and + receives voltage from the switch.
I have no idea how that Mitsubishi would wire if its OTHER THEN a one wire alternator so dont bet your life on what I just posted. The 10 ohm resistor is used in the excitation circuit on the GM 10 SI alternators but NOT on one wire alternators, they are internally self excited.
John T
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
