Re: the alternator, still not right?
Posted by dave2pa on March 14, 2006 at 14:44:28 from (24.144.229.55):
In Reply to: the alternator, still not right? posted by Andrew Z on March 14, 2006 at 10:08:42:
I dont know if this will help or not ,,but i changed my 350 U over to 12 volt ,,a local alt. shop built a GM alternator for me .I have a wire on a spring loaded toggle switch I use to start it charging ,the one terminal just needs a jolt to start the charging.My main wire is on the stud and this one from the switch goes to one of the 2 that plug in the side.Works great just bump the switch when you start the Tractor.Otherwise you have to rev it to very high rpm to get it to start charge.
Dave
