Re: How much paint
Posted by the tractor vet on March 14, 2006 at 17:05:57 from (64.179.117.193):
In Reply to: How much paint posted by Andrew Betzner on March 14, 2006 at 16:48:29:
Well lets put it this way there is 3 1/2 gallons on my S/MTA since you lose to the wind or fan and just paint everything red except the wheels Oh yea there is also a galon of primer on mine so it took 4 1/2 gallons . Even when i would paint a semi mounted plow it took a gallion to do it wright .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
