Re: Super C oil check
Posted by CNKS on March 15, 2006 at 14:39:54 from (204.249.178.138):
In Reply to: Super C oil check posted by LiverNips on March 15, 2006 at 09:19:50:
Only problem with checking the lower one is that if you have an oil burner, check the lower and oil drips out, run it half a day and you could be low on oil. My advice is that it should run out the upper. As mentioned do not overfill. Add 1/4 1/2 quart at a time. If it has only light use and it does not burn oil, do as you wish.
