Re: 686........problem or not??
Posted by the tractor vet on March 15, 2006 at 19:11:38 from (64.179.117.26):
In Reply to: 686........problem or not?? posted by Duane NC OH on March 15, 2006 at 18:29:32:
That came from when that tractor was split probably for a T/A and the mechanic put one or two rubber bands around the input shaft ft bearing to hold the bearings tight so he did not knock any of them out whe he slid the tractor back together . SOOooo don't worry about it.
