Re: 706 1965 model gas
Posted by El Toro on March 17, 2006 at 08:36:29 from (64.12.116.65):
In Reply to: Re: 706 1965 model gas posted by buddy s on March 15, 2006 at 22:48:23:
Here's a trouble shooting procedure for ignition systems using conventional points. Hal No Spark?/ First be sure distributor cap is Dry & Clean. This is for battery/ coil ignition systems.
1. Is there battery voltage at the coil? Use a test lite or volt meter. 2. Is there battery voltage at the coil? Use a test lite or volt meter. 3. Remove distributor cap, rotor & points cover, remove the coil wire from the cap and put it within 1/8-1/4" of a good ground. 4. With points closed & ignition switch on, snap the points open a few times & watch for spark at the coil wire end. 5. No spark: may have dirty or burnt points, bad condenser or a bad coil. Coil primary (battery voltage) wire to distributor from coil must be attached to the - negative terminal on the coil if the battery is - negative grounded. You need to check to make sure your plug wires are in the correct firing order on the distr. cap. This could be the problem with the popping sound you get. Going CW your wires should be like this if rotor turns CW: 4----1 2----5 6----3 If it turns CCW should be like this: 1----4 5----2 3----6
Home
| Forums
Today's Featured Article -
Identifying Your Tractor - by Staff. Maybe you bought it from a friend who didn't know what kind of tractor it was, or perhaps (and this is every tractor fanatics dream) you stumbled across it in an abandoned field covered with weeds but intact. In any case, you have no idea what the make and/or model is. For awhile perhaps it doesn't really matter. Especially if it runs! But pretty soon you'll probably need to tinker with it a bit and maybe buy a part or too. Having a manual is nice. But how does one go about dete
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
