Re: International Harvester Hay Wagon Running Gear
Posted by Ralph Loeffler on March 17, 2006 at 13:58:21 from (24.149.232.31):
In Reply to: Re: International Harvester Hay Wagon Running Gear posted by Brownie 45 on March 16, 2006 at 11:05:49:
Thanks for all the info, it has all been very helpful. I pulled one wheel apart and found than there are indeed two sets of roller bearings about 2 3/4" long with part number 8678T. I pulled apart the best wheel to ensure that I would be able to read part numbers. On the one I took apart there was some damage to the axle but it seem like the most wear was inside the wheel. Apparently the wheels have a removeable, sleeve-like bearing surface. Does anyone have advice about repairing or getting new axles and replacing the bearing surface inside the wheels?
