Farmall Tractors Discussion Board
Re: Re: Re: '52 CUb Hydrolics? for Friend
Posted by Daniel on January 11, 2000 at 16:03:52 from (205.188.197.33):
In Reply to: Re: Re: '52 CUb Hydrolics? for Friend posted by Raymond '54 SA on January 11, 2000 at 12:33:07:
I believe you have the pump and the cylinder unit mixed up. The big cast housing under the gas tank contains the reservoir, control valve and the hydraulic ram, sticking out either side is the rockshaft. Two soild lines run from this housing down the exhaust side of the motor and connect to the small pump, which is bolted to the front of the engine block. The pump is mounted up there so it can be drived from the cam gears. Any leak into the crankcase is through the pump like Raymond said. Hope this helps.
Post A Followup
: Re: Re: Re: Re: '52 CUb Hydrolics? for Friend
