Re: Live Pumps-What other models fit an M
Posted by VOLfarmall on March 18, 2006 at 07:12:02 from (66.19.140.178):
In Reply to: Live Pumps-What other models fit an M posted by Marksd on March 18, 2006 at 06:36:04:
Super M pump will not fit a M if it is IH pump.the bolt holes on top are 1/2 in. wider on the super M. You can make this work by changing the front cover on the engine using a super M cover on a M. Or you can use a M&W pump from a M or super M the holes are slotted on the M&W pump and will fit both. and yes the gear comes off pretty easy. and will fit the IH & the M&W pump. I hope this helps
