? for Haas and others on bearing #
Posted by banjo on March 18, 2006 at 10:41:18 from (65.67.203.30):
You gave me a number for the transmission bearing earlier. Is that a case/Ih number?49339D
do you have the numbers for the final drive and axle? I have the numbers that are on the original bearings and seals.Napa was no help here.basically i need all the seals and bearings for the final drives and transmission.
here are the numbers i pulled off the old ones.
Tranny,counter shaft, ( 49339D)bower- M1207E& M1207,IH GC-230, Main drive shaftIH C-235 & 0-230-T
Final Drive, IH ST-204,IH PL-240
Axle,IH L-250
Planter seal, national 264098R91
Final dr seals,C/R 51494DA & (43283-D in the aluminum housing).Is the latter one seperate or does it come with the aluminum housing?
I'm probably going to have to make a 160 mile round trip to a bearing place to find these, any help is appreciated.
