Re: 706 update. Sat work.
Posted by the tractor vet on March 19, 2006 at 07:55:48 from (66.202.111.68):
In Reply to: 706 update. Sat work. posted by Kelly C on March 19, 2006 at 05:52:06:
I should have told ya about another trick to make them go together easier to go back together , that is take the pressure plate and lay it on the floor and use your heel and push each clutch finger down and place a small nut between the finger and the cover this holds the plate back and then you place the pressure plate on the shaft then the disc on the shaft then just slide the engine into place no wigglen cussen or fighten it then once every thing is boltedinto place you go up thru thr accsess hole in the bottom and start the pressure plate bolts and turn the engine over installing the bolts as you tighten them down the nuts fall out and every thing is like it is suppose to be makes the job go so much easier. Your getting there.
