Farmall Tractors Discussion Board
Re: SA Fuel leak...
Posted by Bob M - I agree w/ Farmer Bob... on January 11, 2000 at 18:45:07 from (171.219.197.17):
In Reply to: SA Fuel leak... posted by Raymond '54 SA on January 11, 2000 at 11:02:43:
Pop for the new sediment bowl assembly! A lot cheaper than rebuilding a burned tractor!
I encountered the same problem on an H a few years ago. Turned out corrosion (probably from sitting several years w/ water in the tank) had eaten away the tank nipple on the zinc bowl casting - gas would literally soak thru what was left of the metal. The bowl just sorta crumbled when I attempted removal. A replacement bowl costing $18 at NAPA cured the problem.
Post A Followup
: Re: Re: SA Fuel leak...
