Re: Water pump for Farmall C 113
Posted by Janicholson on March 19, 2006 at 15:56:32 from (66.173.50.138):
In Reply to: Water pump for Farmall C 113 posted by thumbanger on March 19, 2006 at 15:09:09:
Theere is two parts to the WP, the pump itself, and a mount adapter. The adapter, or bracket, sandwitches between the pump body and the block. It has passages in it that the water flows through.
The belt lines up, but you will need a different one. A thermostat is omportant to use with a WP beacuse they will overcool and run poorly if not up to temp. A 170deg. thermostat can be placed in the top hose with a Plastic ring to keep it in place against the top engine outlet and a clamp around the ring. Be sure to put the radiator side to the radiator, or it will overheat pronto. Good luck.
JimN
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
