Re: hydraulic pump pressure and fluid
Posted by Quebec Red on March 19, 2006 at 16:20:37 from (70.83.254.155):
In Reply to: hydraulic pump pressure and fluid posted by john-wiz on March 19, 2006 at 09:38:59:
Pressure should be in the 1250 to 1400 lb. range. The higher you go the more $$ you will give to Mother Case. Lifting power also depends on cylinder diameter. That oil is , well, OK, as long as you do not contaminate oil being used in a newer tractor. Once your system is free of dirt and water, etc. I recommend HY-TRAN oil. It is superior and worth the money....QR..
