Re: ? 4 H engine experts
Posted by ChadS on March 20, 2006 at 08:11:47 from (66.228.96.152):
In Reply to: Re: ? 4 H engine experts posted by sgtbull on March 19, 2006 at 19:12:49:
if it's a H casting for the block, you use a sleeve and piston kit for a H, now if it has a late model crank, check the part numbers on the rod bearing inserts, that will tell you what crank you have. Late supers-350's had the bigger crank journals, better cam, and head. Look for a 8043DC or DD head casting, thats a good gasser head other than the better SH-350 heads. ChadS
