Re: Need some pointers
Posted by Farmer Bob on March 20, 2006 at 08:36:20 from (71.50.8.53):
In Reply to: Need some pointers posted by Joe Evans on March 20, 2006 at 04:40:25:
If you are starting out a new "Land" meaning there is no furrow for the right rear wheel to drop into, you will need to lower the right side of your hitch to get the front bottom to "Suck".
After completing the first round, then adjust the hitch so the plow is fairly level with the right rear tractor wheel in the furrow left by the rear bottom of the plow on the first go-around. Play around with it until you get uniform depth on all three bottoms. G'luck on your plow days.
