Tie Rod Position
Posted by joe/mass on March 20, 2006 at 13:41:46 from (66.31.73.111):
Replacing the tie rods on my Farmall 130 with adjustable front end. Do the threaded ones go out by the wheels or does it matter.
Thanks in advance Joe
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
