Re: COIL S. M. 12 VOLT
Posted by Janicholson on March 20, 2006 at 18:49:18 from (66.173.50.105):
In Reply to: Re: COIL S. M. 12 VOLT posted by Dellbertt on March 20, 2006 at 14:27:12:
To my understanding, a 6volt coil is to be operated on 6 volts. A 12v coil is one of two types, it is either designed to be used with a ballast resistor (from mid 60's chev, or chrysler), or designed to run on 12v without a resistor. Look in the archives about 4 terminal solenoids if yours has a solenoid. Bypassing the resistor to make more starting fire. A 6v coil on 12v needs the resistor. a 12v coil that (usually) says on it "external resistor not needed" is to be used without a resistor. A 12v coil that uses a resistor needs one. Could you use a 12v needs a resistor coil on 6v (probably) JimN
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
