Re: TA Status
Posted by Nat 2 on March 21, 2006 at 05:51:12 from (64.80.108.52):
In Reply to: Re: TA Status posted by Janicholson on March 20, 2006 at 18:39:11:
Be careful when you say "slow down the tractor."
The TA will NOT slow the tractor down if you're going downhill!!!!! If you pull the TA, you're going for a ride, and you WILL need a new TA afterwards, if not an entire new tractor.
Pull the TA when you're running out of power. Idle back when you need to slow down, or shift to a lower gear.
NOTE: This only applies to mechanical TAs on SMTA, 300, 400, 350, 450, 340, 460, 560, 504, 606 544, 656 etc..
