Re: H stepped pistons
Posted by riverbend on March 21, 2006 at 05:55:59 from (208.160.33.139):
In Reply to: H stepped pistons posted by sgtbull on March 20, 2006 at 15:50:46:
My H started out with flat top pistons and a kerosene head. When I rebuilt the motor, I went with the stepped pistons, gas head, and reground cam. Compression went from about 4.8:1 to 6.5:1. Same starter, same battery. I think that it starts better now, it's like the higher compression makes it pop sooner.
Does your block have a dipstick or a place to bolt on a fuel pump ?
