Re: fuel bowl on gasoline Farmalls
Posted by old on March 23, 2006 at 08:24:05 from (207.69.139.136):
In Reply to: fuel bowl on gasoline Farmalls posted by Yellott Canby on March 23, 2006 at 07:03:26:
Its always a good idea to shut off the gas when you shut off the tractor. If the carb leaks you can end up with gas in your oil and of a hyd lock because one cylinder has filled with gas and even a few other problem includeing $10-40 worth of gas ending up on the ground or in the engine
