Re: W-6 Foible.s?
Posted by chadd on March 23, 2006 at 11:08:17 from (155.92.30.252):
In Reply to: W-6 Foible.s? posted by W-6 Kirk , on March 23, 2006 at 08:53:37:
Sorry, I was going to post this sooner, but I couldn't get on the site briefly. I also appologize in advance for the long post. Differences between W6 and Super W6: Super W6's were equipped with W9 front wheels standard. These wheels were options for all but the last run of W6's Super W6's had a C-263 4 cylinder, W-6's had a C-248 4 cylinder The Super W6 has higher ground speeds in each gear when compared to a W6 Later Super W6's used a channel front frame similar to the Farmall letter series tractors. Early Super W6's and all W6's used a cast tub for the front frame. W6's all used a solid bar with a small spring for a seat(most were changed out). Super W6's I believe had the option for a seat more like that of an M with a shock absorber and a spring. All Super W6's were equipped with a 12" Rockford clutch. Some W6's were equipped with it, but most used Rockford 11" clutches, however, there were a few with Auburn 11 inchers. Super W6's all had IH double disc brakes, while only the last of the W6's got them. A few W6's were equipped with an aftermarket company's disc brakes from the factory. All Super W6's had the flat sealed beam headlights, while the W6's used the bullet shaped replaceable bulb type headlights. The serial number plate on a W6 will simply say W6, while the Super W6 would have something stamped into the plate to designate the fact that it is a Super. The hydraulic systems were pretty much identical between the Supers and the W6's. Both were live. From the sounds of it, you have the pump, the reservoir, and the relief valve (under the cap with 3 bolts). What you need to complete the system would be the hoses to the back of the tractor, the remote couplers, and the control valve, which is the same for an M or W6, except that the M's was located next to the gas tank on the right hand side and was operated by a rod, while the W6's was operated by a hand lever. Not sure where it was located on the tractor, but I believe it was on the left side of the seat. You may want to get a parts manual for it to find out what is all missing. You will more than likely not find a picture of the setup in a tractor book because 1)there were very few standards compared to Farmalls 2)there are very few books written about the standard treads exclusively 3)many W6's didn't have hydraulics, as they were usually used for small chore tasks with older equipment that didn't require or have a provision for hydraulics. Also, the hydraulic attachment for the W6 first was released around 1950, which was towards the end of the W6 production. The M's was available by 1940, which was well before the M overtook the H as the most popular IH on a yearly basis. Good luck with your tractor.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
