Re: Super A,Need help please
Posted by Haas on March 23, 2006 at 19:48:17 from (12.65.72.251):
In Reply to: Super A,Need help please posted by Tim in Va on March 23, 2006 at 17:54:02:
Get a manual!!! Use 90w gear oil in the transmission and final drives. Don't forget the final drives, they are separate from the transmission. Level plugs for the final drives (also serve as fill ports) are located at the front of the final drives between the front lower drawbar attachment holes. Socket type plug takes a 1/2 inch drive. The final drives hold 3 pints each. Level plug for the transmission is behind the brake actuator rod on the left front of the transmission. You have to take the pin out of the brake clevis to get at it. The transmission holds 5 quarts. Maybe closer to 6 if you have the PTO and belt pulley. Use Hytran tractor fluid or equivalent in the hydraulic system. Fill to the bottom of the fill port. When filling, make sure the rockshafts are in the rear position, as that is when the cylinders are retracted and the most fluid is in the reservoir. Also use caution when you remove the fill plug, as there is no vent on the reservoir and pressure tends to build up in the thing and can blow out fluid when you remove the plug. Get a manual!!
