Re: 1086 dual tank sending unit issue
Posted by the tractor vet on March 24, 2006 at 07:03:38 from (66.202.111.42):
In Reply to: 1086 dual tank sending unit issue posted by Ralph J. Butteris Jr. on March 24, 2006 at 06:57:40:
Yep , it is the bottom tank unit that is bad as it has to be in the up posision to get the correct reading on the top one , now it may be just a bad wire so to check that ground the wire from the bottom tank and see what the gauge does if it showes full when the top tank is full the it is the unit in the bottom tank.
